App 8-10 years ago, early in the building process of my hot rod I bought a new water pump. First engine start this autumn showed that the the pump leaks.
I've heard that it's probably because of dry out gaskets.
It's an Allstar Performance aluminum pump. Chevy Small block engine.
What do you suggest? Buy a new pump, or buy a back plate gasket kit and replase this?
Will the axle gasket dry out over this period of time as well?
I'm not able to see if the leak comes from only the back plate gasket, or from the hole below the axle as well.
