For some reason, the solder I use won't properly "sink" through the wires and instead, will just form a puddle above the wires and won't adhere them together. Bit of a problem that's been leaving me scratching my head. Been using wire that isn't terribly old, but still wanted to eliminate it being that problem. Took brand new wire, stripped the ends and attempted to solder the end for a test. Did the same thing, just globbed on the surface and wouldn't properly sink through, doesn't matter what gauge the wires are either. What is going on? I am doing it the proper method by heating the wire and letting the wire do the actual melting. Could it be a defective piece of solder? I'm using lead free solder, .062" diameter, flux core. Should I switch to silver solder or perhaps another suggestion is in order?
