Hey guys, I have been reading htis site for quite a while. It has been very helpful. I have a problem that i can't figure out and I was hoping someone on here could help.
I have built 2 engines, a 383 and a 454. They both run pretty good. I couldn't get the timing right on either one, so I timed them by ear. When I put the light on the timing is reading around 60 degrees.
I must be doing something wrong but have no idea what. I checked true TDC by using a piston stop and rotating clockwise, put a mark then ccw and put a mark and scribed the middle of the 2. One motor was right on, the other was 2* off. I have the firing order 18436572, have timing light on #1 plug wire, yes i'm on #1. I have tried 3 distributors on one motor and I tried 3 timing lights, 2 of the lights showed the same, one showed 3* different. If I put the light on cylinder 6 it shows the exact same thing.
If it really was 60* I don't see how it could actually run, let alone start. If I slow the timing down to where it should be it dies before I get there. What am I doing wrong?
I thought for sure it was me because it's 2 motors and 3 lights. I told a buddy that builds dirt track motors to set the time. He said why can't you, i said just see what you come up with. He did use one of my lights. He was under the hood for 15 minutes and he said I HAVE NO IDEA WHAT'S GOING ON.
Sorry for the length and thanks in advance.
