A buddy of mine just sent me this and since there has been a lot of discussion about welding safety here and because body panels are likely to be cleaned with chemicals I thought I would post this in this section. This is something we all can be exposed to if not careful there and there can never be enough warnings because some will miss them and some will forget but it CAN happen!
www.brewracingframes.com/id75.htm
I myself got very sick a few years back when I welded on a heavy steel casting that had just returned from the machine shop and there was some cutting fluid (or maybe cleaning fluid) still in a hole that had been threaded. The hole had been drilled in the wrong place and I was going to plug weld it so it could be re-drilled, even though I blew the hole out with compressed air there was still enough fluid left in the threads to cause a real problem. Since it was just a "quicky" weld I did not bother with my respirator (BIG mistake!) but as soon as I hit that 1 1/2"hole with the MIG welder I hit the floor! When I was able to stand after a few seconds I felt as if I was breathing ice cold air and I was weak and trembly for about an hour then I had a headache and muscle aches for about two weeks. I don't know if there was any permanent damage or not but even after 15 years sometimes when I don't feel so good I have to wonder. Anyway what happened to me was not nearly as bad as what happened to this guy but as I said IT CAN HAPPEN!!!
