Today I got to a little project I am doing for a customer of my brothers. It is painting the charcoal color on the centers of some rechromed Buick "Road wheels" from a mid sixties Riv.
The color formula is only available in an aerosol from Semour paints and I thought I would keep it at that. This is the type of thing that I would commonly spray out the color from the aerosol can and then match that in a base coat or SS and bla bla bla. I didn't want to get into that on this job.
Just tape it off, scuff it and shoot this "Cast Blast" over an aerosol etch primer. I didn't want a primer out of a gun for a few reasons, the big build up at the tape line and the mess being I was just going to do a wheel a night being they are such a pain to mask. But I had second thoughts about the etch, did I really need it. This Semour paint comes with high recommendations, is that 1K etch doing to be any improvment?
So I pulled a chrome bumper out from behind the garage and did a little test. I laid two strips of masking tape and scuffed the chrome with a red scotch brite pad just as I plan on the wheels. I sprayed one strip of tape with the Rubber Seal etch primer that the Winzer supplier had given me to try. Just holding a piece of cardboard over it to keep overspray off the other tape. Then painted the whole thing with the Semour Cast Blast.
I took off to the store and came back to give it a test, the finger nail scratch test. The Cast Blast came right off like nothing! But I COULDN'T take off anything where the etch primer was!
There was nothing more to think about, I used the primer.
Just a few minutes prep and I learned something and feel much better about this project.
This darn etch primer is pretty awsome for an aerosol and may be the ticket for some smaller projects of yours. It is available at the Medallionrefinish.com site under part number RS-517. And while you are there they make the best weld thru primer I have ever used. It is called an "Etch weld" primer and holds on MUCH better than any other weld thru I have tried. You know how that zinc rich primer has no adhesion at all, this stuff is different and really holds on pretty good. Not as good as a "real primer" but MUCH better than other weld thru "coatings". By the way, I did a rust test with that primer against a couple of other etch aerosols, a S-w and the etch that I used on the wheels. I sprayed a strip of sheet metal in three sections and then did a cross hatch scratch. The RS-512 held up the best showing hardly any rust after many, many months (maybe a year, I forgot to mark it with a date) outside in the weather.
