Great question. I'm not sure howo to tell?Do you have teflon liner's on your rotor's?
Greg
Greg
Seems to be a lot of opinions on intake gaskets lol some folks really like the ones with the seal around the port and some don't. These are the ones recommened by Promaxx for these heads. The first picture is the intake. There is essentially a port mismatch. The ports on the supercharger intake are smaller than the ones on the heads. I was told that using the ones for the larger ports is the correct choice? It does seem that it moved a little off center, though, when I installed it.looking at your picture's and wondering what type of gasket's you are useing.
I never liked the print o seal gasket's. On your first picture I will assume it is the intake and it look's like you have a gasket mismatch. Makes me wonder if the blower is pulling oil out of the valley into the induction track.
Greg
Yea its unfortunate that the gasket matches the heads perfectly, but the runners for the intake are a lot smaller. There isn't enough meat there to even try to gasket match the intake. I'm certainly open to suggestions on a different gasket to use?You are right on gasket opinion's. In our shop's there is all ways a small arguement about what type of gasket's the mechanic's prefer.
I think I would try to get a better match on my gaskets to the head and intake.
I could be wrong not being there but I am starting to think that the gasket's might be some of your problem's.
Greg
It is unfortunately a weiand intake. Says weiand in it lol. I’m gunna go back with these gaskets again and see what happens. If there was enough material on it I would truly and gasket match the runners. There’s not near enough meat in the bone!Yeah
That doesn't look like a Weiand intake. Not sure what you have.
If you have the part's you could go back to an na with a carb and see how your truck run's.
Drive it a few days and see what happen's.
If it does the same thing then I am not sure where to go with it.
If it was here we could figure it out.
Greg
Maybe so. Who knows. Maybe it spun after I initially set it and it’s been correct. I mean, 20 degrees is a lot lol. It would be cool if it picked up some power, though!That would explain why it was running so lazy.
Greg
