1 - 8 of 8 Posts
CLICK ON MY AVATAR
What are the advantages of running a 180* thermostat vs a 195* thermostat?Does the engine work harder running a 180*thermostat?thanks bm
No...it just runs cooler....180 is a good temp to run. You may want a little hotter in the winter when using the heater.
Some engines do run a little better with a hotter thermostat. What motor is it?
Heater works better w/ 195F.
Extensive study showed increased engine wear as operating temps dropped.
As I recall, wear started increasing at 180F or so and got progressively worse as engine temps declined.
1 - 8 of 8 Posts
