I have a 383 stroker, here are the specs on it:
The rods are 5.700 stroke (a little longer) Molly rings with forged flattop pistons, the whole bottom end was balanced.
The heads are from a 350 engine they have had a 3 angle grind job on them, and had stronger over sized valves installed with bigger springs for a higher lift cam. Up to 540 lift. Manley valves 2.02 intake valves 1.60 exhaust valves. The cc of the head i believe are 68 which would make the compression ratio 9.7:1.
Crower cam grind: 288hdp lobe center 112 intake 288 exhaust 296 duration @ .050 intake 234 exhaust 246 gross lift .497 .504 crower hyd lifters and single springs for the cam crower aluminum roller rocker arms ARP stud kits for heads and journals ARP bolt kits for everything else (intake, exhaust, carb, timing cover ect ect).
High flow oil pump with extra volume oil pan ( i think it takes 8 qts)
edelbrock timing adjustable timing chain.
edelbrock performer RPM air gap manifold
Accel HEI distributer with HEI unit
Accel 8.8mm racing wires
363.6 HP @5200
407.5 torque @4000
Ok, I have what i believe is a holley 650 double pumper, the only id number on it i could find is:
3310-10
0413
Is this a appropriate carb to run on my motor? If not what should I go with?
The engine is going in a 68 el camino.
I also have a old school holley carb which i was told is a better carb than the 650 double pumper. the number on that is:
0690
list-4360-2
I was told this carb needs to be rebuilt but can be jetted a bunch of different ways and would be worth rebuilding.
Any and all info and input is appreciated.
363.6 HP @5200
407.5 torque @4000
3310-10
0413
0690
list-4360-2
