Got a 383 stroker in my 66' Chevelle. Running 373 gear in posi/spool 10 bolt. Have headers, 750 cfm 4150 Holley, 2000 stall, Dart Eagle Heads 200cc, 2.02"/1.60" valves, Hydraulic Comp Cam (Extreme Energy) kinda mild at .477"/.480" lift, 224 @.050 268 degrees/ 280 degrees adv. dur 110/ L/C. 10.25 compression Rod length 6.00", MSD, Forged Pistons; Turbo 350 auto trans. mated to a Gear Vendor. Oh I also have NOS 200 hp dual shot. I have x-pipes that turn down at the axles. Also running on 8" street tires.
Since I am on a budget (aren't we all) what do you racers recommend first for a streetable week-end quarter miler? I will still drive it on week-end cruises and shows. Which of the following will give me the best affortable POWER: Ported Aluminum 215cc heads, a bigger bump stick (range?) and Cam kit; higher Stall 2,800 to 3,200; 4.10, 4.56, 4.88 gears; and/or Cheater slicks?
The engine is rated at 405 hp and 454 torque. Would like to get to 500 hp or more without the NOS but I'll keep the NOS.
