ok i have an 82 s-10 put a 350 in it with 3.73's in the back. had a TH350 with a 3500 stall conveter. the 350 was mildly but and my buddy put a huge came in it. thats why had to use such a high stall...now im redoing the top end using a trick flow street/bracket top end kit ,it comes withheads, rockers, & a 228-224 duration @ .050 cam with .480/.494 lift says motor should produce 420 horses and 395 ft lbs of torque. i might go with the other Street kit, it comes with a cam that has 210-216 duration @ .050 with .440/.454 lift. says motor should produce 350 horses and 400 ft lbs torque.
the question is what converter should i go with for each setup. truck will be prolly a daily driver ?
