Awesome response. thanks for the reply! Why is it so common on japanese engines? I never understood how so many of my friends slap on turbo kits and take a tune off the internet and go drive. This must be what happens when you don't put the correct tune on the engine or understand whats really going on.
Is the history of this engine known, as in has it seen nitrous or turbocharging?
My take on it would be that the limits of how much boost or nitrous/compression was found and almost exceeded. Looks to me as though he got away w/it- but barely. The cause could be excessive boost or nitrous use even w/a good tune on the engine, too much timing for the conditions (this can occur naturally aspirated as well as boosted), insufficient fuel octane, overheating, lean air/fuel ratio, to name just a few.
Also my opinion, the head fasteners weren't originally designed to hold the kinds of pressures seen under heavy boost/nitrous use. There are studs and such to help keep the head and block together w/o a failure of the head gasket seal, but even then there are limits. Considering how much power these small import engines make under boost, I believe their durability is
exceptional.
Under the extreme conditions seen when running a lot of boost or nitrous, the small amount of damage seen is almost routine, especially during the dialing in phase where the limits are being found. On the other hand, if the engine was NA I'd be very concerned about the tune because it would need to be far from ideal to see that happen unless boost/N2O was involved.
I'd be curious to know the history of it, though.
