i am going to start building a twin turbo motor i have been planning to build for a while but i wanna get some advice on some engine combos that would work well and save some money
i wanna keep the stock chevy heads i got off a short block i bought and never used
should i go with a higher lift and wider LSA cam and go with bigger springs?
i already have it in the making to go with a master rebuild kit that comes with all the gaskets and a set os forged speed pros
do you think i can get away with using the stock crank?
main thing is that i dont wanna invest in an expensive set of heads when i already have a set that has never been used and i dont wanna buy an expensive crank
i just want the engine to handle a low boost twin turbo setup maybe 10psi
any advice is appreciated
