what is a hot rod?
Cruising Ram, very insiteful thinking. Good idea.
Actually, this debate started some 30 or so years ago, and it started as what was the difference between a street rod and a hot rod. Back then it seems that concept was that a hot rod was a vehicle built somewhere back prior to 1950, and a street rod is anything later, in chassis and body.
In the general vernacular of hot rod, I contend that its any vehicle that has been modified from its production condition.
Im not sure I would call a vehicle with just a fancy paint job and some body customizing a hot rod, as the term emplies modifications to the engine.
That being said, whether its a 2 liter 2000 Honda (yuck), with a modified computer, or a 502 Gorilla block, with all the whistles and bells, technically, it does become a hot rod.
As for the comment that it has to be a V-8 doesnt hold water, since most of the first hot rods were Model T 4 holers, with Rajo heads, igloo water pumps, winfield carbs, etc etc etc.
Its like Jazz. Someone once asked Louie Armstrong what Jazz was. His reply was if you have to ask you will never know.
As for what is a hot rodder, that is easier to define.
Its a person that takes a production vehicle and makes changes to it so it will perform as he desires it to, altering the engine, suspension, custom body work.
A true hotrodder is not arrogant concerning brands or type of engine, and while he may talk smak about blowing your doors off, also respects what you have done to your vehicle, and appreciates the work, and TLC, you have put into it.
