zz71s said:
It seems if you have a head milled down to raise compression ratio this will change the heads air flow spects.
So,what is more important air flow or compression when trying to make max HP and torque?
Both but there are associated circumstances that mange their selection.
Compression has a large effect on engine efficiency which then controls both fuel economy and power output. An engine needs a relationship between the fuel it burns and the power ot produces. An engine that burns a lot of fuel for the power output simply throws unused energy out the tail pipe. This costs money and power.
The compression has two aspects one is Static Compression Ratio (SCR) which is the mathematical ratio of all the cylinder volumes divided by the volumes above Top Dead Center (TDC) of the piston. This needs to be in agreement with the cam timing as well. Long duration, late intake closing cams need more compression to recover power lost to low RPM reverse pumping. This latter thought will lead into air flow and the Dynamic Compression Ratio (DCR). The higher than ordinary compression used with long duration cams is not usable with short cams because it results in excessive low and mid range DCR that isn't compatible with available fuel octane ratings.
The DCR gets into the air flow capabilities and cam timing of the engine. This is a variable compression ratio that changes in proportion to the instant volumetric efficiency of the engine at any particular moment of operation. Roughly speaking, when engine RPM is low to moderate and the throttle mostly closed, the density of the mixture is low (another way of looking at it is the manifold vacuum is high). In this situation the air flow in the ports is also slow and the cam's intake opening time After Bottom Dead Center (ABDC) results in reverse pumping of the intake charge by the piston back into the intake. At this point dynamic compression is low and close to the statically calculated ratio. At the other extreme of high RPM, wide open throttle; the mixture density is high (manifold vacuum is low) and mixture speed in the ports is high. This gives the mixture a lot of inertia and it will continue to flow into the cylinder against a rising piston until the intake valve is closed. At this point the Dynamic Compression Ratio is higher than the Static Compression Ratio. These are the effects of the fact that gases are compressible and will change the number of molecules for a given volume (density) based upon the forces being applied.
An engine's torque peak is a good indicator of the point where breathing (volumetric efficiency) is as good as it will ever get. Above the torque peak the ability of the cylinders to get a full breath starts to drop off becoming shorter and shorter of breath as the revs go up. What's happening is horsepower keeps going up for a while, this is the cylinder producing less power on every revolution, but being able to make more revolutions in a time period, so torque is falling but horsepower is raising for a while at least. Assuming nothing mechanical limits the RPMs by a failure, the horsepower will continue to a peak after which it falls off. This peak is the point where the engines ability to get even a short breath is no longer enough to keep going on and the horsepower curve flops over. So one can construe that Volumetric Efficiency falls off above the torque peak and for practical purposes of getting power ends with the horsepower peak.
So the answer to your question is both compression and air flow are important, and work together. You can trade them around, but this has to be done in relationship to how the engine is to be used. Obviously having and engine with variable compression and variably sized ports that can change with speed and power demand would let you build and engine that was flexible and maxed for efficiency and power in all conditions expected of it. But the engineering of such a situation is simply beyond our technical capabilities.
Getting to your basic question of head milling affecting air flow, it doesn't have any effect. Milling doesn't change the dimensions of the ports at all, other than lowering the head and manifold a few thousandths of an inch. It doesn't change the location nor angles of the valves or ports. To a great extent the same can be said of angle milling the head. This will change the angle of the valves to the cylinder bore but not by much. But more importantly it doesn't change the angle of the valve in relation to the port, where heads built with the valve angle changed to that lesser than Chevy's usual 23 degrees like the 18 and 15 degree heads, also, move the valve relative to the port which improves breathing.
