As already stated, the stock repop fel pro gaskets work great and are cheap, I`ve reused the same set 3 times over about a 5 year period. There made of metal mesh and are at your local parts store, it`s identical to the factory gasket and there difficult to burn out, another good thing is you don`t have to remove the bolt to install them, just loosen the whole header and drop them in from the top. However, here`s a few more tips, if the headers are new and the bolts are new, you have to retighten them often, every few days, other wise the bolts loosen due to them not being seasoned in. Also paper header gaskets, even so they don`t say so, are supposed to be soaked in water so they`ll swell and the moisture will help the gasket last longer.
