Hello all,
Haven't been on here in a while. I have been researching about rust treatment, POR15 and silver bullet. I can't conclude what I should do. I need some advice based on my specific situation.
I want to clean up the backside (inside section) of the door skin. What I have done is cut the sheetmetal which would be the Inside piece in the car. This is the metal that the door panel upholstery would mount to.
So now I have easy access to the door skin from the inside. This is where all the water would drain down from the glass. There aren't any holes from the surface, just lots of scaling and surface rust.
What I have done is scrubbed and rubbed all the rusty metal with a Emory cloth. This got rid of alot of the loose rust (came off as dust, my sinusus hated me the next day). There is still some of the surface rust (dust) on the metal but it seems that no matter what I do I cant get rid of it.
I want to treat the metal somehow to protect it and prevent any further rust from starting. Keep in mind that in many spots I can't spray in a uniform manner. And some areas are so tight and ackward that I can't even get a brush.
What do you suggest I do about treating this surface rust? I can take some pictures tomorrow if that helps, but I don't think I could really capture this situation with a picture.
My concern about POR15 is the fact that is needs to be top coated ALSO all the prep work is a major concern. IN those tight spaces and ackward corners I wont be able to really clean the rust with an emory cloth or other prep method.
Rust bullet is another option but I can't find much data on it.
Eastwood has a chemical called Rust Converter. This seems like what I need, but I believe that even requires a top coat of paint.
They also have Rust Encapsulator which looks and cost similar to Rust Rullet but there is even less data on that.
What do you suggest I do. Please only provide facts and base your response on personal experience.
Thank you
Thank you
