1 - 12 of 12 Posts
The plastic Door pannels on my 76 GMC pickup are all faded from the sun and the dash pad is tired too... I thought the cheapest way to refresh them would be to paint with a rattle can.
I plan on doing a red & black interior and most pannels are a kinda burgundy color not near red enough for me.
Question is what kind of paint will not be affected by the UV and will stick to the dashpad and door pannels ?????????
Or am I totaly on the wrong track????
Thanx guys... Suggestions and Ideas are appreciated.
Bill...
use dupont paints from your auto paint supplier.forget about spraycans...they can make any color in the rainbow 4 u.they tell u to us it straight,no thinning,but i find that it adheres better with a little laquer thinner.wipe down the panels with it too!3m makes a textured primer if the grain is gone.
Bill, I got a local autobody paint supply place to mix up some vinyl dye in spray bombs. They can mix factory colors. One warning, if you've ever used armorall or similar product you'll need to clean thoroughly. I used SEM plastic prep cleaner as a final cleaner too.
I've tried this quick fix spray paint repair before and unless your prepared to totally dismantle everything and mask alot, not to mention clean try to lightly sand glossy surfaces, it is real messy. I also found that the sprayed surfaces when dry have a real cheap plastic look to them afterwards. I'd say go with the dye the others talked about or even try to get replacement panels and dash if the trucks worth it. Nothing beats the factory look. Good luck and have fun.
I DYE INTERIORS FOR A LIVING. I DO WORK FOR AUTO DEALERSHIPS IN MY AREA AND HAVE BEEN USING SEMS PRODUCTS. REGULAR PAINT IS TOO BRITTLE AND FLAKES OFF IN TIME, MAKING A MESS. SEMS PRODUCTS AND OTHER DYES ARE MORE FLEXIBLE AND DRY IN A MATTER OF MINUTES ( LAQUER BASE PRODUCT ) . STAY WITH A PRODUCT THAT IS MADE FOR THE MATERIAL BEING SPRAYED. AND, JUST LIKE EXTERIOR PAINTING, MAKE SURE TO PREP YOUR AREA, THE BETTER YOU DO THAT, THE BETTER IT LOOKS AND LASTS...
1 - 12 of 12 Posts
