drelotter said:
Hello there. :welcome:
I have a Chevy 350 bone stock with aftermarket aluminum heads. The are the Dart Pro 1 Aluminum Cylinder Heads. I don't have too much experience with builds I wanted to know what ratio rocker arms 1.5 or 1.6.
I don't know if there is an importance to which one I choose Please help me out thanks!
Go with a roller fulcrum rocker, not just a roller tip. The fulcrum is where you will see a benefit.
In the case of a stock cam, you will gain a little performance by using 1.6 rockers on your 350 with those heads.
But WHY run the stock cam? Those heads will benefit from a good cam, chosen for the application that you have for it. Even a mild cam- fully streetable and computer compatible- can get you 30-40 plus HP more than the stock cam.
The way I look at rocker ratios, is use a higher ratio when the base circle gets too small due to the lift required. If I were starting out w/a blank piece of paper to design a valve train, I would lean towards a 1.7:1 ratio from the get-go. Engines that have been designed w/a 1.5 ratio from the start will have less issues with clearances, etc. when staying with the 1.5 ratio.
For any given cam, a higher rocker ratio will provide more lift under the curve than the lesser ratio rocker. There will also be more open duration, without changing the opening and closing points.
If the valve train is going to be modified, a higher ratio should be considered- but be aware that there are current lobe designs out there that have the ramp speeds about maxed out. To use 1.6 rockers on these cams may invite trouble.
In any event, get a decent cam in that thing!!!
