Suppose one picks a cam that has too high a lower band, say 2500-5500, and then wants to bring that down a bit. From what I understrand, advancing the cam a bit can do this. One thing I read is an advancement of 4 degrees will only move the powerband down by about 200 rpm. So for anything more significant, it would seem that it would be best to switch to another cam instead, even though I have timing gears that allow up to 9 degrees via a number of keyways.
I have read a couple of forum posts, ...can't remember where... of the Crane Fireball cam (which I have...294 adv) really bringing an FE BB alive if advanced 4 degrees. Do you think that's a valid point?
One other thing, a lot of what I read seems to overly complicate matters for me. I assume that 4 degrees advanced means advanced with respect to crankshaft degrees. But then some say, 4 degrees is built into some cams as the lobe centerline is off by 4 degrees,, hence a deviation from "straight-up". Seems to me that a person wanting to advance a cam by 4 crankshaft degrees means just that, 4 degrees advanced from the zero position recommended by the cam manufacture regardless of where the lobe center angle is.
Comments are most welcome. Thank-you.
