I'm building a 1969 Chevy C10. Its done for now, but later i plan on doin more to it. The question is how big of a stall on my converter should I choose? The motor is a 307 bored 0.30 over, block decked 0.20 off, heads are World S/R Torquers 58cc chambers, stainless valves, decked 0.20 off, total of 0.40 off to bring compression ratio up to 10.1 on premium gas. Has a Comp Cams hydraulic big-thumpr cam #K12-602-4, 243 intake, and 257 exhaust duration @ 0.050, 500 intake and 486 exhaust lift, 107 lobe center, double Isky valve springs #6005, 8.000 inch Summit pushrods, guide plates, 7/16 screw in studs, Harland Sharp roller rockers 1.5 ratio, HEI street/Strip distibutor ProComp, Edelbrock Performer RPM intake, both heads and intake port and polished to match, with fel-pro gasket, long-tube headers, Holley 700cfm double pumper no choke. I building up a 700R4, with all the good stuff, billet servos, best clutches you name it, its Monster Transmissions master kit good up to 600 hp, its over kill but for $800 for everything its worth it. Im thinking of using a 4800 to 5000 stall converter. Let me know what you guys think. Thanks, sbc307.
