I've been eyeing osme of them up on ebay. What recommendations for auto upholstery?
Oops, my bad. The list of Consew machines I have doesn't list 166 or 167 as one of their model numbers, but there obviously is such a machine. It appears that this machine might be a predecessor of the Consew 206. It has a bobbin case that is vertical instead of horizontal, and you need to remove the bobbin case to change bobbins. It also uses a standard industrial needle size of 135X17. If it is close to a 206 in specifications, it would work fine for auto upholstery. The listing in Seattle Craig's list has expired, so no way to look at it there.DanTwoLakes said:As far as I know, Consew lists no such machine with that number. There is a 106R, however. This is a lighter weight industrial machine, and has only a 1/2" presser height lift. I'm not sure if it is a compound walking foot machine, but I think it is just needle feed. Here is a link to a manual for that machine: CLICK HERE If that's what the machine is on Craig's List, it would not be a the best choice for auto upholstery.
A home machine can handle a lot. They have the strength to sew through many layers of fabric. What they don't have is enough lift height to get as much under the foot as car seats require. They are also probably not going to have a compound feed system. If you're only sewing a few layers of fabric together, it will work fine. If you're trying to sew two layers of sew foam and fabric together, you will be disappointed.Microsoft Paint said:Hey Dan do you think a Kenmore Zig Zag machine would be able to handle light interior stuff like door panels or stretching it a bit.... seats.
Pfaff is a well known brand in the US, Adler not as well known. Adler is the best sewing machine on the planet as far as I'm concerned, and Pfaff is a close second. Adler industrial machines have 1/2" shafts throughout where other machines only use 3/8" shafts. The problem is that they are expensive to start with and hold their value, so getting a bargain on a used machine is hard to do. If you can find a good deal on either one, jump at it.UngerMarkus said:I don´t know what the market is like in the USA, but I would recommend you an "Adler" or a "Pfaff". My granddad bought the the first Adler back in the 50s and it is still used in our company every day and it works just fine. Parts are readyly available and those machines keep their value pretty good.
Sure modern machines offer some benefits, like alternating transport, clutch-less step motors, air-pressure operated thread cutter and foot lift and so on... all stuff you won´t really need.
