On a High Horsepower 350 pump gas what is better?
Flat top pistons combined w/the chamber volume needed to get your target compression ratio is the best formula in nearly every case.On a High Horsepower 350 pump gas what is better?
^^^^times 2Flat top pistons combined w/the chamber volume needed to get your target compression ratio is the best formula in nearly every case.
Depends a whole lot on where in crankshaft degrees the cam shuts the intake. A high horsepower engine usually means a really big cam, this looses a lot of torque off the bottom end that needs to be restored; the method of recovery is through higher than expected compression. Obviously 93 unleaded does impose an upper end to the squeeze, but none the less you're probably going to be shoved to push the limits.On a High Horsepower 350 pump gas what is better?
