Let's say for a moment that the cons of running a thumpr cam are starting to out-weight the pros for me.
Can I get some help figuring out a cam that would produce either equal or greater power than my thumpr, but with better drivability\easier tuning?
Engine info in quote block:
It stinks often, and I had to drill butterfly holes in my carb, and my manifold vacuum is low. The car shakes back and forth when I try to drive at a slow idle, but that's probably just because my rear is still like, 2.73 or something highway like that. But it does sounds beautiful.
But I guess if I could get more power with the same lack of drivability\tunability, then why not?
I've been tuning it about a year now and have it running pretty decent. 18 degrees advanced with 18 mechanical (seems like both dizzys I bought, cheap one and then this nice one came already set to a small amount of mechanical advance, almost as if they know they were going in a thumpr. Unless, of course, I'm just flat out doing something wrong.)Had a stock 350 sbc short-block built for me (he cleaned a block then bored and honed it to 355), with complete brand new rotating assembly and the smallest thumpr cam (flat tappet).
He chose and built the heads for me. Procomp, aluminium. I don't know the exact part number, but they are aluminium heads, 1.5 lift roller rockers. I wanna say these heads here are close but I can't be sure.
Edlebrock air game RPM intake (nascar edition).
Holley (proform) 650 double pumper.
