bwomp969 said:
I was wondering if someone could either point me in the correct direction to learn about what everything means with exhaust ports and etc that would help explain whats what about a SBC head?
or maybe someone could just tell me?
Im thinking about cast iron large port vortec heads but to be honest I really dont know why they cost so much compared to normal vortec heads, cast iron of course? and is there a major difference in aluminum vs cast iron?
Don't sweat exhaust ports. There are 1000 HP motors running 250 CFM on the exhaust side.
There's a whole lot on heads, nothing that can be summed up in three sentences or less.
Aluminum is all about heat. They get rid of the heat better than cast iron allowing for higher compression.
I posted here a long paper I spent weeks developing and researching. I'll see if I can find the link.
on't be fooled by flow numbers. Those who brag about flow typically don't understand what makes a head work.
There's elements like flame travel, fuel suspension, cross sectional areas, etc...
The whole purpose of a head is to suspend fuel and deliver it effectively to the cylinder. The best way I know of to do that is
1. Wet flow, used by all but 2 manufacturers, Nascar, and all other high end engineers
2. Spintron with high speed cameras. Allows engineers to see exactly what is going on while the motor is running in its operational conditions.
Runner design is more important than flow numbers and these techniques help define what that means.
I'll see if I can find my link.
