This may belong under the builds section not sure... I was intending to start a build thread tonight but... oh well.
So I recently bought a 350 short block new off ebay, it looked absolutely fantastic, turned by hand nicely. 4-bolt main, bored .060, forged pistons, decked to 0, melling HV pump, stock crank and rods, aluminum heads with dual springs and a rubberized gasket, ARP head bolts, moly pushrods .2+, aluminum 1.3 roller rockers (for break-in, 1.5's for later), comp cams additive, comp cams assembly lube, .480 lift 230 duration, hydraulic lifters installed dry (as instructed by the paper which came with the cam) 10w 30 oil, bypass blocked, primed with electric drill, then primed again by cranking with the starter, fired it up, 70psi oil press, kept idle at 2000rpm's, within 5 min. CLACK CLACK CLACK CLACK!
Thought it was just a rocker which came loose, one was loose, tightened it up, (zero lash, then 1/2 turn, then tighten the center lock) and the sound was still there, just now it sounds like a grind then a clack 10 times a second, and one cylinder sounds flat... I believe it just chewed a lobe...
So here I was thinking I could just toss in a new motor into my 52 and be able to go to college, and get a better job, without buying a whole other car, but I guess some people just don't have that kind of luck. Not to mention, this is the 3rd motor, none of which I could get any sort of luck with, and now im completely broke...
Thinking on the bright side, It was my first motor I have built myself, it was worth a shot, achieved something that most could not, and it was a thrill hearing it fire up. Too bad the noise just sounds way too nasty to be anything normal for a fresh motor.
Who wants to see a build thread anyways? I took a few pictures along the way.
