· Registered
Where can I go or buy dash cluster? I want to take the factory cluster out that I have in my 89' Mustang LX. I want to put all new gauges and buy a pod or something to put the gauges in where the old cluster was. Can anyone help me on where I can find or what to do to customize my dash in the matter?
· Hot Rods are Built, not Bought
Typically adds for gauge panels peddlers show up in most street rod mags, like Rod & Custom or Street Rodder Magazine.
Check out the following:
www.nordskogperformance.com
<a href="http://www.silcarcorp.com]www.silcarcorp.com[/URL]
· Registered
here is a solution that I used on my k5... pretty simple, cheaper then aftermarket clusters, and you can even use a piece of brushed allum. instead of the factory bezels. design your own.
· Lost in the 60's
You could make a dash panel or bezel out of wood walnut for instance and coat it with high gloss poly-urethane. If you do not like the wood look then do like solowookie suggested and use brushed aluminum
