21 - 25 of 25 Posts
If you have a Fred's Store in your area, their house brand oil, made by Warren Oil Co., has 10w40 and 30HD oil that are both rated SL. The guy at Warren I talked to last year said their SL oils have ~1000ppm of ZDDP in them. Warren also makes Coastal Oil products, so watch for that brand, too.
Try the store locator at www.fredsinc.com
While it's not SL rating, instead it's earlier SE/SF rating- this inexpensive oil is the one I used (along with 2 small bottles STP) to break-in the cam on my 406 and it worked fine. I've found an inexpensive oil at WalMart that is still formulated to SE/SF ASI ratings and contains between 1-5% ZDDP. It's called ACCEL brand and is made by Warren Petroleum Products of Omaha,Ne .
Sounds familiar, eh?...
While I'm sure Joe Gibbs brand, Brad Penn, and all these other High-Line oils are all very good products. For those of us "on a beer as opposed to champagne budget", I don't see any problem in running oils from Warren Petroleum Products. After all, we are hopefully changing oil and filter on a very regular basis, aren't we? So long as proper additives are present in proper levels, and we are keeping it clean, isn't that the most important aspect? All oils breakdown and get dirty. Perhaps some a bit faster or slower than others, but they all do.
Discussion Starter #24
I found Coastal oil in a place I never thought to look.....Tractor Supply.
It is a 30 wt oil, but has the old SE/SF rating. It should be good for break-in.
Don
Should be no reason it couldn't be continued as regular/ongoing usage. Especially in your situation where engine is of older (1960's) design and you live in a pretty warm climate. Far superior to what it ran for many years, right? :thumbup: -Jim
21 - 25 of 25 Posts
