crane specs:
Part Number: 100052 Grind Number: 272 H10
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1957 1987 CHEVROLET 8 GOOD IDLE, DAILY USAGE, OFF ROAD, HIGHWAY TOWING, FUEL EFFICIENCY PLUS PERFORMANCE, 2600-3000 CRUISE RPM, 8.75 TO 10.0 COMPRESSION RATIO ADVISED. (50 STATE LEGAL, PRE-COMPUTER, C.A.R.B. E.O. D-225-21) BASIC RPM 2000-5000
Engine Size Configuration
262-400 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 3027 @Valve 454 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 3027 @Valve 454
Rocker Arm Ratio 1.5
Cam Timing: TAPPET @.004
Lift: Opens Closes ADV Duration
Intake 27 BTDC 65 ABDC 272 °
Exhaust 67 BBDC 25 ATDC 272 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99848
Loads Closed 105 LBS @ 1.700 or 1 45/64
Open 265 LBS @ 1.280
Recommended RPM range with matching components
Minimum RPM 2000
Maximum RPM 5000
Valve Float 6500
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 3 BTDC 33 ABDC 105 216 °
Exhaust 43 BBDC (7) BTDC 115 216 °
comp specs:
Grind 268H, 454 Lift, 268 Duration, Great For 305-350, Provides Low End Torque, Mid RangeGreat For Daily Driver, And Tow Vehicles, Good Throttle Response and Good Torque, with Slight Noticeable Idle1500-5500 RPM Range .
I know these are super close in specs.Is one better then the other?For a sbc with 1800 stall convertor.bm
262-400 C.I. V
Part Number 99848
Minimum RPM 2000
Maximum RPM 5000
Valve Float 6500
comp specs:
