I'm just about done planning for my first engine build, and so far, thanks to the help of many fellow members here (especially TI), I have most of the parts that I will need picked out. Now I need to figure out which gears would be best for my particular application. It's an 86 chevy pickup. 1/2 ton 4x4. It will be a daily driver, but it definitely needs to have some snot! I'd like decent acceleration but I need to be able to tow the occasional project home as well, so I need some kind of a balance there. Towing is the least important of the two.
Here's the setup so far:
350 block. 0.030" over. 9.012" deck height
L31 Vortec w/ Z28 Valve Springs (0.525" max lift)
1.5:1 Ratio Stamped Steel GM Rocker Arms
Edelbrock Vortec Performer RPM Air Gap Intake
Summit Hypereutectic Flat Top Pistons
COMP Cams Xtreme Energy Cam and Lifter Kit (includes timing set)
-- Hydraulic Flat Tappet
-- 268/280 Dur
-- .477/.480 Lift
Hedman Hedders - Street Headers 1 5/8" tube, 3/8" Flange, 3" Collector
Holley 4160 750cfm Electric Choke Carb
-- 268/280 Dur
-- .477/.480 Lift
