Hello,
I am putting a '57 corvette engine in my '41 Ford coupe. For this application I am adapting the Chevy motor to the early Ford flathead type transmission. I am using a vintage Offenhauser aluminum Chevy-to-Ford transmission adapter. I am using the small, 153 tooth flywheel. The starter bolts onto the adapter (bellhousing) with the three bolts. This is similar to the original system whereby the starter bolted onto the cast iron bellhousing. Since I am using the smaller flywheel......What starter can I use for the starter drive teeth to mesh with the smaller 153 tooth flywheel?? Can I change the starter drive to one with more teeth or is there a complete starter available to bolt onto the adapter that will spin this motor. I think an engine-block-mounted starter is out of the question.
Thank you.......Kenny
