im looking to put together a nice small block 350 for a 72 chevy p/u... i need reccomendations for transmissions... a lot of people i talk to seem to have high opinions of the 700r4 but i just seen a thread that says they have common problems... and i have a couple of bad experiences with 400's... so any suggestions would be appreciated thanx
josh
Premium Member
I know some have their issues, but what doesn't . We're getting set up to put a 700r4 behind a 440 dodge in a 68 imperial.
Chrysler Imperial=4500# of great lakes pig iron hauling barge.
We are buying one already built by a reputable company. I believe a stage 3 trans from Bowtie overdrives is about 1300.00 outright. There are other companies.
Set up your TV cable right, Pick the way you want to switch the lockup, put a big oil cooler on it and go.
Go and look around in the knowledge base in the transmission info and articles. Lots of stuff there.
Later,
mikey
josh
Are you running a stock or HP motor?
Towing?
Street , strip ?
rear end gear ratio?
:cool:
Discussion Starter #4
Towing?
Street , strip ?
:cool:
not towing...
street
about 500hp and undecided on rear end gears yet... wouldnt mind suggestions here also :evil:
