I wonder if I'm asking the wrong questons....
I specifically asked him for white primer or a tintable-white primer...Maybe he does have a sealer in white....I am now assuming these are different?
I am no professional painter....This is my first paint job!
I needed a primer with a good fill in order to be able to block sand down...I think I was asking for a white primer filler, which could be my error.
Sometimes I am really unsure of what I need to ask. The guy is really nice and treats me really well, he even gives me the "body-shop price"...Whatever that means...From shopping around I think he's treating me good, I just think my lack of knowledge is an issue in that I may not be asking the right questions....
This has been a real learning experience for me and I think I'm catching on okay, but I still have A LOT to learn!
One guy on here, Kustomizer, gave me some really good tips as far as the process goes, but a process will only get me so far.
I am using the Cross-Fire line of paints sold by my local Napa. The product is not top-of-the-line, but I have heard that you can get good results with it if you follow the mfr guidelines, which I have been trying diligently to do by pulling the data sheets etc.
Sometimes, I feel like the info I get from the 'pro painters' is the same thing that my jobber is telling me, but the products seem to change a little-I guess not everyone makes the exact same thing....
So here's where I am at thus far in my painting project, and I have read postings that both agree and disagree with the steps so far, so let me know what you think...
1) I am using a bc/cc system.
2) The main color of the car will be chalk white.
3) I would like to add some ghost/phantom flames(still a BIG maybe). Also, if I do this, what will make the most subtle flame on white? I just want to barely see them.
4) I stripped all of the paint off of the car and shot it with self-etching primer to seal the metal.
5) This weekend I plan to shoot it with the 2K primer I bought yesterday. 3-4 coats.
--Yes, I know make sure it is clean....Tack it....Blah blah blah...
6) Then I will block sand the entire car. I am reading that here I should use about 220 grit paper.....Wet? The reason I ask is that I heard that primer will soak up water.
7) Once it is smooth I will probably shoot one more coat of primer, which if I can find some in white this is where I would like to do it...
8) Then I will shoot the base coat of white. 3-4 coats. Should I sand between coats?
9) Then the clear. 2 coats wet-sand flame area w/ 400 grit then paint the flames.
10) Then another 2 coats of clear to finish it off.
11) Finally wet-sand the entire car with 2000 grit and buff out.
I am a real perfectionist when it comes to this stuff, so I have been taking my time, so as to not have a rushed, crappy result.
I know the products I am using will not last forever, and the result is not going to be perfect, but that's okay, I plan on using this as a "confidence-builder" for my next paint job. Plus, you never know I may just suprise myself!
You all have been so helpful! Thanks again and let me know if I am on the right track.
Okay, now if you are all still awake...Please respond....THANKS!!!
