Title pretty much says it, I'm putting fiberglass leaf springs on the front of my '49 F-1. They are longer and wider than original, plus I'm moving the shackles to the back of the spring.
What I need is a set of hangers and shackles built to spec. I will also need a source for all related small hardware as none of the stock parts will fit.
I know you can take a piece of 1/4" plate, put a couple 90* bends in it and drill some holes and you're set to go, but when I had a local metal shop bend a small retainer the bends were not parallel and the hole was off center. Not encouraging for someone I was going to ask about making hangers.
