With low down force drag cars like Pro Stock, anything that gets them out of a straight line by only a few degrees will cause them to lose control. This is often caused by a loss of traction, but could be any number of things like a flat tire, broken suspension or driveline parts, steering overcorrection, wheelies, wind gusts, bumps, debris, or irregularities on the track, etc.When suddendly a drag car turns to one side and crashes, is it usually due to a broken axle or what else?
thanks
I don't know, I've seen old W.J. pedal quite a few out of shape prostocks..With low down force drag cars like Pro Stock, anything that gets them out of a straight line by only a few degrees will cause them to lose control. This is often caused by a loss of traction, but could be any number of things like a flat tire, broken suspension or driveline parts, steering overcorrection, wheelies, wind gusts, bumps, debris, or irregularities on the track, etc.
That's why you see them lift and immediately pop the laundry when they get out of shape. The chute works to stabilize the car and helps bring it back into line.
The fuel classes have an automatic chute release anytime the engine blows or lifts the burst panel or even if the driver doesn't follow the shut down sequence correctly after the finish line. This is combined w/a fuel cut off, maybe ignition too but not sure on that. But they don't use it on Pro Stockers, and for the life of me I do not understand why not.the parachutes should deploy automatically when a sensor detects some veering, this should be mandatory.
The thing is, IMO there's too little time and distance before an out of shape Pro Stocker hits the wall and/or goes upside down for the roof flaps to deploy and correct the vehicle's yaw, pitch, or roll, etc.The auto fuel cut off and chute deploy on fuel cars is to get the car shut off and slowing down if the driver is knocked out by a blower explosion. There is a few bug in it still. All it take is a break in a connection for a few micro seconds and the chutes come out. This has happened several time this year on the starting line. It would have happened more often but some drivers have a way to disable the system while staging the car if the starter turns his head.
Yes cars will still hit the wall if they get out of shape with a Nascar style system in use but they would stay on the ground and right side up.
