A customer of mine sent a block to have splayed caps installed and be align-bored (400 SBC). He also had the shop handle the crank turning (they farm it out).
Upon return of the parts, we checked them out.
The crank was a couple of tenths under the low limit on the mains (the rods were ok, just needed polishing). However, the big problem is the mains have .002" run out on 2 of the center mains, .001" on the other center main. Too much.
The owner of the speed shop (big name, big dollar, big ego place) was informed about the crank. His reply was that he never had a problem with the cranks and that we are checking them wrong. (!)
We check them on a set of V-blocks with a dial indicator (on our balance machine). Just like it SHOULD be done.
But Mr.Attitude says we should check them between centers! Apparently nobody showed him how to check a crank.
What irks me is that instead of saying "Gee, if there is a problem with the crank, let me check it out and we'll get back to you. But no, his way is to blame the guy who DID check it. (Mr. Attitude didn't even bother to check it, anyway!).
Now, the block.
The main bores are between .001"-.002" out of round. I haven't informed the guy about this, yet. I'm probably checking it the wrong way (a dial bore indicator that reads to the .0001".)
ARRRRGGGGHHHHHH!!!!
tom
Now, the block.
ARRRRGGGGHHHHHH!!!!
tom
