GMM is probably GM Morraine
The Morraine is one of the bearing names mentioned in the small-block books. If the bearing numbers are all over the map, I'd be tempted to try and by the same bearing numbers from GM if possible -it could be that it's not the crank that is out of spec, but the block bearing bores. GM doesn't seem to make reliably sized bearing bores (obviously others will write that they have never found one out od spec here). Other than that and some mixing / matching, grinding the crank AND line-HONING the block would fix it. I have just run into a simialr problm -the 350 I am rebuilding had a rough crank, so with a regrind by a reputable machine shop I ended up with variable clearances all about 0.001" over max. Irritating problem.. so far I am considering checking a Target Master crank with 0.001" under bearings to see if this lands in an acceptable range. I don't even want to think of balance at this point...
'Reminds me of the saying 'Measure twice, cut once"...
