To start with i might have cracked a skirt on a piston in my 327 [felt good at 5000 so 6000 must be better] motor had a rattle like a wrist pin under a load about 3000, adjusted timing back to 12 initial, was at 14, 480 480 engle e-p22 cam, dont hear rattle anymore but have not turned it too much since, i wanted to know if the wrist pin height is the same on 350 pistons or is there some other problem, since 327 pistons are way higher priced for any good piston.
Sounds to me like you were getting detonation.........backing off the timing would nelp that. If the piston was broken, you would still be hearing it.
327 pistons cost more, because the 350 ones are so common.
i guess it could have been detination, would higher octaine gas help, im running 305 58cc heads, not for compression, just broke my good ones, with my flat top 2 valve notch pistons, what would my compression be 9 to 1 or so, Ill give her a good run this week. if no noise i want worry, new rebuild less than 1500 miles this little 327 has made a beliver out off me. Wormy. P.S. Thanks for the help everyone. :D
