1.6 rockers
I would advise not to install the higher ratio rockers. Small block chevy heads will flow just as much air at low rpms with the factory rockers as they will with the higher ratio rockers. If you were to install the new rockers, it would have a negligible effect on torque. The higher lift is only necessary at high rpms because the time the valve stays open becomes so short. Also, changing to a higher ratio rocker arm will put more stress on your lifters, and it will change your valvetrain geometry for the worse. Chevy used 1.5 ratio rockers on the small blocks for a reason. If you were to build a high revving small block for a light car, I would encourage the higher lift, and higher ratio rockers, but not for a heavy car where torque is more desirable. You can save yourself the money and the headache by just running the factory rockers. You already have excellent lift and duration for a torquey motor.
