1 - 17 of 17 Posts
I know this would probably be better in a tech forum but I'll try it here since more people frequent here.
I read in the body exterior forum that welding galvanized steel can be really dangerous and make you sick.
I always knew I was dangerous but my friend told me if I have enough ventilation I'll be fine.
So I welded galvanized steel a month ago but I did it outside since I knew I needed ventilation. Nothin' ever happned after that but now I'm kinda scared. Do you guys think that if it woulda affected me I woulda noticed by now?
Mike
current hot rod: CTS-V
You should be ok, the damage is already done. Now if you were diabetic I would say get to the hospital quick, but your only 16, low chance of that.
Ghetto Jet said:
man I could have run with this one.
Dude, I'm only joking. As far as I know it's just hard on your body. Like painting with out a mask or something.
Ok here we go http://www.finishing.com/164/33.html
hey i wasn't wearing ventalating mask's while we layed primer, and i got feeling pretty good and giggly. next morning was hell.
should i worry...... :eek:
Putting extreme heat (welding) on galvanized metal will produce lead oxide vapors, which are toxic. It's a cumulative effect, and unless you get a huge dose, you won't feel it, but the lead will accumulate in your body and you will get symptoms as you get older. When you are young and invincible this isn't an issue, I suppose.....
The lead will accumulate in your body's fat cells and there is no way to flush it out, so once it's there, it's there forever......
welding
The sure sign that you got to much is you will get flu like symptoms the next day. If you were exposed to alot of fumes the symptoms would be really bad.
Your ok........ but i strongly suggest you don't weld it no more... it does bad things to you body.....
Keith
machinest & A&P Mechanic
stores in your fat cells? sounds like lipho (SP) suction has more than one benefit! but then whats your liver do?? so what you guys are saying is that its kinda like asbestos and you wont notice it for a long time.. i guess i really screwed myself up when i inhaled enough kerosene fumes (washing parts) that kerosene was all i could smell for a new days and my throat was sore (could have been a cold to tho) might haunt me when i am like 30...
Discussion Starter #9
or what I do is slap on thick coats of bondo and then get the grinder out and put a sanding disk on and sand all the bondo down. In short time the bondo is EVERYWHERE in my garage in little dust particles, that bad for the lung to0?
Mike
Hey Mike!
Mike, and everybody else too.
Heres some safety info for you.
There are also a couple of links you need to read. Just like it was a school assignment.
Here's the one on Heavy Metal Poisoning. No not the Styx song. well sortof.
and a quote from it:
Symptoms will vary, depending on the nature and the quantity of the heavy metal ingested. Patients may complain of nausea, vomiting, diarrhea, stomach pain, headache, sweating, and a metallic taste in the mouth. Depending on the metal, there may be blue-black lines in the gum tissues. In severe cases, patients exhibit obvious impairment of cognitive, motor, and language skills. The expression "mad as a hatter" comes from the mercury poisoning prevalent in 17th century France among hatmakers who soaked animal hides in a solution of mercuric nitrate to soften the hair.
This is a PDF on Welding Galvanized Iron safely
The first line of defense in dealing with zinc oxide fumes is welder training. Welders should taught -- even when welding uncoated materials -- to keep their heads out of the fume plume and to position themselves relative to the air flow around themselves so fumes and dust do not collect inside their welding shields. If a welder finds white dust inside his welding shield when welding galvanized products, he is not positioning himself properly. When welding galvanized products that have thin, uniform coatings and the process is gas-shielded MIG or flux core, the gumes generated are sparse and the shielding gas blows them away from the welder; this is frequently sufficient to avoid metal fume fever without further action.
To complement proper positioning, a fully effective method to preventing inhaling zinc fumes is to wear a suitable respirator (mask).
Some of the commercial products which are suitable are:
Manufacturer Product Description Cost ($ each)
3M (800-328-1667) 9920 Half-Mask, Disposable 4.50
3M 9925 Half-Mask, Disposable 5.00
3M 9970 Half-Mask, Disposable 6.50
Moldex 3400 Half-Mask, Disposable 6.00
Here's some stuff you should know.
1. Always wear a dust mask when grinding or sanding. Paint and Resin (Epoxy, Vinyl etc.) materials can cause allergic reactions even if they are labeled "non-toxic. Most of them are toxic. Even completely inert substances, when inhaled as small particles, will damage the lungs.
2. Wear gloves Dust from Bondo type materials cause allergic reactions when in contact with the skin. It affects some people more than others but chemicals from the resins are absorbed through the skin and may cause liver deterioration over time.
3. Safety Glasses! I would hope I wouldn't even have to mention them except if you are working in heavy dust they should be goggles or a ventilated hood.
Isn't there a safety manual on HR somewhere? I swear I've seen this discussed.
I'm pretty up on this stuff because I was able to trade doing a Safety Manual for a place in return for blasting and priming my front clip.
Roy.
Start those projects someday
When ever you weld galvanized metal you should always position yourself upwind of the work surface and work in an outside well ventilated area. I always use a fan to help blow the smoke away also. Position the fan so it blows at your face and not the weld area, or else it will blow the shielding gas from the work and the work quality will suffer .
Before reading all the technical information that will likely bore you to tears, read what a real person has to say (click here) .
Eric, known as Sevt_Chevelle here on Hotrodders is a great guy, just turned 27 last week (happy birthday Eric) and is damaged for life from ONE exposure to zinc fumes. Weld thru primer, ecoat primer both are very rich in zinc, just like galvanizing.
Like I tell the guys at work when I see them without protection, you aren't always going to be a young stud, one day you will be an old man. You want to get there safely, you want to be able to enjoy your retirement, not laying on the couch with an oxygen bottle.
Don't play games, don't joke about it. It is NOTHING TO JOKE ABOUT.
And for Gods sake don't use the old "its only a little bit" line. All these "little" exposures add up. Like putting that change from you pocket in a jar every night adds up. Next thing you know you have $500.00 in pennies, dimes and quarters and lung cancer. :)
If every time we grab one of these chemicals, or sand or grind "just one little weld" or weld a little weld without a resporator (weld thru primer is about 99% zinc, can you say "zinc fume fever?) or something, and don't protect ourselves because it is "only one little _______", we are dropping a few coins in the jar by our bed.
Nightfire- if it has been a month then you have nothing to worry about. Just don't do it again! Welding galvanized metal can be very dangerous since it gives off zinc oxide and small amounts of lead. This is one of those things some people do many times and seem to get away with, but the risks are too great and if it does get you then you are in a world of hurt. I am not saying that you should not weld galvanized metal, I am just saying BE CAREFUL! Use a welding fumes mask EVERY TIME such as a 3M 8212 disposable or something similar and do not depend on ventilation alone to protect you. I am pleased to see someone your age thinking about safety as what you do now can have a profound effect on you later on in life. I,like a lot of others,suffer from things I did years ago that I never gave second thought to at the time. You will never regret working safely but you may regret an unsafe act for the rest of your life!
Welded a few pieces of galvanized bar for a seat bracket in a closed garage once. I was sicker than a dog that night. You had better believe I don't even think about welding any galvanized without extra precautions now. I was an experienced welder, it was a cold day and I just didn't give it a second thought when I closed the door. DO give it second thoughts - EVERYTIME.
I work on home respiratory equipment for a living. I'm in and out of the house of people with breathing problems all day long. The most prevalent of couse are the smokers. But after that, are the welders and painters.
Good point!
Next time its a pain to put on a mask, think what it would be like strapping one of your welding tanks to your body so your lungs will work.
New to this forum, so just came across this thread, and thought it appropriate for me to enter this reply.
In 1968, as an 18 year old fresh out of H.S. I was employed by the Fisher Body Division of Oldsmobiles Lansing Michigan plant, where my first 5 years were spent working in the 'Arc Booth' welding and brazing on the Olds 88 and 98 (B&C body) production line. (Olds first hired me at 16, but thats another story)
In particular relationship to this thread, one position that I held was mig welding the galvanized trunk floor pans, which required leaning far into the trunks. Normal production in those days was in the range of 300-350 bodies per shift.
Although we were provided with large overhead mounted fans to dissipate the fumes,there were no masks, in the course of welding, our disposable welding shields would become permanently coated with a white deposit from the zinc welding fumes, progressively obstructing vision, so the shields were normally replaced twice daily, at starting time and 4 hours latter after lunch break.
I was on this trunk welding job for several months, until problems with my sinuses bleeding, got me transferred to a different position. That was 36 years ago, and I'm still around,
and I still do a lot of welding, That said, I still fear there may ultimately be long effects on my health from exposure.......
1 - 17 of 17 Posts
