I wanted to know if not having a cooling fan on your car (91 Camaro RS) would be enough to make it overheat. Could the fan make the difference between the car overheating and not overheating. I really need an answer to this question so anything you know would really be appreciated.
"May the Schwartz be with you"
YES.
Your car has airdams under it to effectively cool the engine while in motion.
When you are at a stop light (or any other non-movement period), there will be no air flow through the radiator and you will overheat. The fan is there for the non-movement periods.
I suppose if you can drive without ever stopping and also happen to live in a cold environment you may be able to get by.
ya that's what i thought. i was just makin sure. thanks and if anybody else has anythin to say bout it let me know.
Premium Member
Faster than Bill Clinton can undress an under-age inturn!
