Premium Member
As long as your current cam is a hydualic roller setup it should fit. Before bidding I'd e-mail and ask for the specs on the cam.
Any particular reason you are wanting this cam instead of something new and aftermarket? I'd be very hesitant to buy a used cam from someone. IF you are going to do this I'd try and get the roller lifters from him as well. But I dont recommend buying this cam.
Never, I repeat, NEVER buy a used camshaft. There's way too many good aftermarket NEW cams to choose from (at very reasonable prices I might add) to ever make it necessary to purchase a used cam.
Centerline
Premium Member
Especially seeing as this is a stock grind for the LT-1's. Not a bad grind but it was certainly improved upon by GM's Hotcams and by other manufactures.
