The switch on my car a 81 TA is a 3 speed switch pulse to high.When i put the wipers on pulse and to low and to high it works fine,but when i go to the off position,the wipers work on slow speed,if i use the washer mode they also work fine and turn off back to hidden off position.Now in pulse or high or slow speeds the system works fine only when i go to shut them off in the off position the wipers are in slow mode, the only way to get them off is to shut off ignition and restart to set the wipers back to the hidden park positon.Sorry about the run on and i hope this makes sense.Thanks all Tazz.
