Not sure how far apart the studs are for the wiper blades, I'm also assuming these guys all work the same way in that the driver's side and passenger's side blade move in opposite directions like a 55 - 57 chevy. I'd recomend looking at pacific western design's wiper setup. If what you have is shorter than the tri-fives and you have similar clearance with the ducting under the dash, you could cut the rod down. Would be even better if they were the same but I doubt they are. Anyhow, its a solid kit and eliminates the cable transmission mess.
