Just wondering how to wire up a kill switch on a 64 Galaxie
hallamwillis said:Just wondering how to wire up a kill switch on a 64 Galaxie
WHAT DID HE SAY?!?!?!eugeneragsdale said:i had a 78 chevey scotes dale truck luved it to death i had 3 switches 1 was power the key switch was also power some thimes started whin it wanted and the 3rd u started the truck then let off of the switch to kill the starter the 2nd switch you had to have on to start the truck flip the switch it would kill the truck just like the key would do i would like to do this to a 70 cheve luv any ideas![]()
Doc here,pasadenahotrod said:Had thieves try to steal several times but couldn't get 'em started. Only time ever a successful theft was when an employee did not flip the switch. He was just running in someplace for a minute. Bing, that's all it took. We did get the truck back not damaged too badly, but never lost another.
Doc here,T-bucket23 said:I always use the other approach. I used to put a switch with one side to ground and the other to the neg side of the coil. When closed it would take the points out of the circuit. The bennifit to this is that the coil cant be hotwired. With the cutting the hotwire method, a simple aligator clip on a hot side wire will allow the vehicle to start. The other thing if if the switch goes bad you can still start the car with the grounding method. if you use the cut the hot method and the switch dies, you are walking
matt167 said:how about the simpilest kill switch you can think of. the cigarette lighter, run the wire to the pos side of the coil, rather than to power, when you need to shut down, pop the lighter in and the system will ground out, engine will die.
Doc, it creates a short to ground, that's how it works. the lighter element, is what works as the switch because it connects power to ground. I know people who have done this. but could even run it from the - side of the coil, because it would just ground out all the time, rather than pulse ( and create voltage ), just saturate, and the motor would die that way also.docvette said:Doc here,imp:
How does that work????![]()
The positive side of the coil IS Power...And the positive side of the lighter has no relationship to the body ground side of the lighter except when run through a resistive heating element of the lighter..
If you ran 12 volts through it to ground the lighter would work fine the coil would not..and if it had a path to ground through the lighter, the coil power wire would just burn up..To do something like that you'd need a lighter ISOLATED off body ground, and has both power and ground wires running from it..
Docimp:
matt167 said:Doc, it creates a short to ground, that's how it works. the lighter element, is what works as the switch because it connects power to ground. I know people who have done this. but could even run it from the - side of the coil, because it would just ground out all the time, rather than pulse ( and create voltage ), just saturate, and the motor would die that way also.
this method is normally used as anti theft, and not as a kill switch, but it works anyway.
