I have recently installed a complete new wiring harness, and new gauges in my 48 Aero Sedan. While wiring the gauges, I looped all the ground wires, from gauge to gauges so that I would only be grounding one wire. Then I looped all ground wires for the dash lights. The gauges were working great, and then I noticed that my guel gauge was registering, intermittingly. Then the temp gauge would peg to maximum. I removed the dash, rewired the grounds, and rehooked everything. they would work, and then intermittingly again. Yesterday, while driving the car temp gauge was at full peg, and I turned the headlight switch from dim to bright and I noticed that the temp gauge would fluctuate from normal (175) to max. I set the headlight switch so that the gauge was working. I apparantly am not getting a good ground, but I have checked and rechecked at connections, used a star washer between the body and connector. HELP
