Doc here,
imp:
Always install your wiring over the insulation..the insulation can hold Vapor and wear on the continuity of the harness over time, It can also cause problems if you must shoot screws to hold interior parts.
If you have an area that has no support for Wiring, and can't be secured with screws, Don't use the stick type or plastic bundle fasteners, Heat from the exterior of the body as well as the heater/cooling vents can cause the glue to let loose and the plastic to rot..leaving a harness bundle drooping on your pedal controls and feet..
I advocate getting a 1/8 X 1/8 in piece of aluminum Angle stock, and fixing it between the two nearest supports on the body, and attaching your bundle to it using metal , rubberized Adel Clamps. Use either a threaded 6/32 hole or a nut, star washer, and lock washer at each clamp. For the strut mounting you can use screws, but Pop Rivets are much better.
Doc
imp:
