I have new speedpro pistons and scat 5700 bushed rods. Some of the wrist pins slide in pretty easy and the wrist pin spins in the piston and rod. a few other pins spin freely in the piston but it doesnt spin in the rod. I use assembly lube on anything the rotates/spins/moves I was able to push them in by hand, but they dont spin in the rod like its a pressed fit. Is this normal? Will it loosen up after first start up and it warms up? or is something wrong here?
Another question. After I installed new main bearings torqued them down to spec (I didnt forget to seat the thrust bearing) It seemed like the crank was frozen.It took some effort to break it free, but once it is moving, it spins very freely. But after it sits for a minute it freezes up again. I feel this is normal but im unsure.
