Hi all-
I'll do a little intro post in a bit, but I've been searching the forum and haven't come across the answer to my specific questions. I've been very impressed with the knowledge I've found so far, so I'm hoping we can put our heads together and get some answers. Let's say my experience level is decent with small blocks as I've built them successfully in the distant past (warm 355 in a 1965 Chevelle bracket racer, stock 400 sb in a 1969 Blazer, 350 in a 1971 Monte Carlo, etc.).
My issue is that I have a bigger cabin cruiser boat that when all loaded with fuel, anchors/chain rode/other gear, spares, tools, fishing gear and 5 150# people scales out at 7640. So, a slow heavy boat. It has a volvo-penta 280 outdrive on it and had a the AQ255 motor (that's a basic stocker 350 from 1977). I've always felt this motor was severely underpowered for this application but ran it because it was reliable and that's what it came with when I bought it last year. It took forever to creep up on plane in decent weather and light wind chop, but if you try and get up on plane in anything over a 1-2 foot wind wave it just couldn't do it. I was thinking about going 454 marine engine (280 outdrive can handle the torque) but this 355 gave up the ghost earlier than I planned. I do have an Edelbrock performer intake, Edelbrock 1409 650 CFM Marine carb and a Mallory marine points distributor.
So, thinking that the quickest/cheapest route was a local rebuilder that does marine long blocks, I ordered one up and started yanking out my old one. Delay after delay (ever tried pulling an SBC out of a 27' boat on a trailer in your driveway before??) brought me to the end of boating season and a chance to re-think this before I put the boat back on the moorage for next season.
What I have from the machinist is a basic build - a .060 over 010 block with rebuilder pistons and stock "low rpm marine cam" (hydraulic flat tappet and no cam card came with engine). Stock 1.94/1.50 76cc (882 or 993 castings, can't recall now). Due to the outdrive, I have to use a 153T flywheel to bolt the drive adapter to.
What I'd like to know is how would some of you guru's go about getting the most torque out of this motor in the 2800-3300 RPM range? Looking for fuel efficiency as well (110 gallon gas tank just ruins my day at the fuel dock). I'm thinking just taking the block and swapping in an internally-balanced 383 kit. Interally balanced because I could re-use my stock flywheel and I have an nice 8" balancer for the 350 already. What kit/brand would you go with for that? Is the 64cc Vortec head conversion in my future? Worried about static compression ratio, as I need to keep it under 9.5/1 or my already-expensive fuel goes up in price. No need for lift to go over the .450 range due to the use here, so no need to mod heads for that. This motor will never see the high side of 4000 rpm, and with the prop I have it will need to cruise right at 3000 for hours on end. Idle MUST be smooth and as low as possible (600 RPM max) to handle shifting the outdrive in and out of gear without damaging it and moving around in tight spaces. Everybody else's boat around my moorage space is a lot nicer than mine and I don't want to be swapping gelcoat with them because an engine stumbles shifting in and out of gear in a tight spot!
I think that's about it. Hope to have some of you guys jump in and throw suggestions out on how to do this right the first (ok, second) time. Cams, bottom end kits, heads, intake (if I go Vortec), etc.
Hans
Hans
