I love low-end torque. Blame it on youth spent on 2-cylinder "Poppin' Johnnies", B&S 6.00x6.375 inches, 60 hp @ 1125 rpm
The 401 is a GMC "Big Block" 60-degree V-6 truck engine made from 1960-66.
210 [email protected] rpm, 348 lb.ft @1600 rpm. 4.87"bore, 3.58" stroke, 7.5:1 CR, "Pass everything but a gas pump." Engine is the "Magnum" version with bigger head passages.
What can I do to improve gas mileage?
With the low CR and massive 4-ring pistons is this a candidate for a turbo?
Would I be better off grinding crank to use modern rods and pistons to raise CR? This would also involve lightening the crank (which is not a bad thing!)
There's also a crank with 3.86" stroke that could be offset ground for even more stroke.
Would any of this improve the gas mileage? I'm wanting to make some trips in it but cost of improvements could pay for a lot of gas.
But more torque is always a good thing
