i was thinking if i had extra cash to play with,,, i would like to try to build a 4.5" bore with a 3.76" stroke engine... obviously it would be a 396 crank in a 502 block... i know the big thing is to add stroke, as i have built a very nice 489 with 602 hp and 594 ftlbs...
also being obbssesed on the 302 Zapper small block,,, what would a short stroke - big (huge) bore big block run/rev like,,,throttle response?, red line?... obviously the low end torque would be not near as a 4.25 stroke,,, a wild mechanical roller or solid flat tappet would be the only way to go for the revs. 320cc heads?
. i also thought of a 400 small block with a 3.00" stroke... i guess it is obvious,,, i love to hear an engine scream into the stratosphere... we all want torque down low to get the car moving but the hi-end range once it gets moving is nice,,, i had a 350 LT-1 with a .30 .30 cam that i got away with reving to 8000rpm(no ****) many times.i was 21 and was in early 80's when certain things were not frowned upon......no .. please respond with what your ideas are on the big bore /short stroke big block ,,, the engine would be a 70 Nova or something in that weight category...i think it is a great idea, but may be shot down by some of you guys...
